ke1x
    26
Everything posted by ke1x
  1. it's a 30 year old car. the original head probably spat a welsch plug and self destructed long ago. doubt there are many old corollas out there with the original engine in them. 10-15 years ago you could buy japanese import K series motors everywhere. not many people would spend a grand plus for a reconditioned 3k, when they could get a fresh import 5k for around $500. the first jap 4k i bought cost $425. 3k's weren't much over $300. pity you can't get them like that anymore.
  2. maybe just rock up to one that is open and ask???
  3. plus your cold air induction :P
  4. newer ones do. 5ks were produced around 1983-92. KM30/36 liteaces had 5k's. 7k's have the longer stroke. you need to do sump mods on 7k's. at least to go in the earlier ke1x series. may not be such a problem in a later corolla.
  5. no, the stroke is the same between 4k and 5k (73mm). 5k cranks have 4k cast on them. same crank. 5ks have larger bore 80.5mm, k/3k/4k have 75mm bore. just be careful as some 5ks have a thicker flywheel, which can cause clearance problems with some earlier boxes in the bellhousing. you could always use an earlier 4k flywheel if this is a problem. probably not a problem with your later injected 4k. 4k-e isn't it? think the 5k's came standard in vans (liteace?).
  6. i think you will find you would be legally required to meet the ADR requirements of the year of manufacture. think the ADRs started in the early/mid 70's. 1974??? my 73 HQ holden was pre emissions. PCV system only. 75 ke30 ADR plate, but not much in the way of emisions gear. the earlier ke1x series have a simple dump pipe for crankcase emissions. all the blowby is directed down the gearbox tunnel under the car. it's so complex :P haha...sorry, just wanted to try that smiley ! really so long as you do things neatly to pass a visual you should be fine. just make sure anything that needs to be plumbed into the airfilter still is if you change to an aftermarket item. ballbearings work good in vacuum lines.
  7. what's a pollution control? thats why i drive a ke15. pre ADR's
  8. (Wednesday) June 2 - Rollaclub Test'N'Tune---yep, if i get this weber better sorted. (Sunday) June 6 - Rollaclub BBQ Cruise; Hinz Dam--- we'll be there (Sunday) June 13 - All Toyota Day----be there for a look (Sunday) June 20 - Motorkhana 3, Southport--- for sure, so much fun to be had.
  9. ke1x
    Carby Fun
    pics didn't work :P try these...... probe1 probe2 probe3
  10. had a few hassles getting my son to school this morning. driving along and the car starts spitting and farting like it was running out of juice. the fuel guage was low, so i assumed it had run out of fuel. the car stopped, so we went for fuel. get back, put a tin of fuel in and the car starts first pop. weird, it should have taken longer for the fuel to pump through. anyway it is still doing the same thing. i work out if i give it full throttle and slip the clutch i can still get places. anything below full throttle and it would just die. after i got home i started the car and sprayed carby cleaner around the base gasket, the engine instantly stopped. ah, major vacuum leak. one of the 8 studs on the adapter plate for the DMTT weber had stripped. i found another one long enough to put a nut underneath, problem solved. the car runs so much better, and i can now set about sorting this carb out properly. some pics of my afternoon project below. bit rough, but for the money who cares.
  11. best i've ever done is have a welsch plug blow out of the back of a big port head 3k. happened a week after getting my first car (ke30) on the road. :sad: being young and not really knowing any better at the time i kept going, until it siezed. it started a few minutes later and i kept going, just trying to get home. after 4 seizures (and cooloff periods) i finally made it. the engine wasn't really healthy, but still went. pulling the head revealed badly scored bores. lesson learnt. motor change time.
  12. weird, click on the link and you get a page unavailable. take the "share" out of the URL and it works??
  13. here is a good chapter on carbs, from A. Graham Bells' book "Tuning New Generation Engines for Power and Economy" http://au.geocities.com/ke1x/carb.zip good carb selection and tuning info. Doug
  14. yea, i'd lean the carbied 4ac myself. it's already in your car, and no wiring nightmares. you need to just not mind playing with carbs. you should join the yahoo Carburetedblowers group http://autos.groups.yahoo.com/group/Carburetedblowers/ search through the archives, tells you all you need to know about modifying carbs and fuels systems for blowthru forced induction. basically your options are: to put a carb in a sealed box, and pipe boost to it. or seal the throttle shafts to minimise boost/fuel leakage, and run a carb bonnet. also need to make air bleed mods. seems halving the air bleed area stops carbs going lean under high load boost conditions. you could maybe use your existing carb if you were to put it in a carb enclosure. maybe something more tunable like a 32/36 DGV weber would work better with a few mods. you just would need a high pressure fuel system and rising rate fuel pressure regulator. some twin turbo v8 guys simply use a mechanical pump, and simply pipe boost to below the diaphram, where the vents were. this makes the pump add an extra psi of fuel pressure for every psi of boost. have seen cases of guys using a normal adjustable return style fuel pressure regulator and putting it inside the box, when running a carb enclosure setup. the FPR thinks the boost level is normal atmospheric, so always stays your 4 psi or so above the boost pressure.
  15. i was more refering to the rear suspension setup and diff. looks like an RC car. an L18 might be a bit of a tight fit in a ke15 :) have thought about it previously, have a datto nut friend. mmm DCOEs are nice. sound good too.
  16. not sure on the cost of the DMTT. i sort of scored it for helping a mechanic friend do up his RX4. the carb came off a turboed sigma, converted to blowthru, then EFI. very luck score. don't have a bonnet for it yet. not bad having the potential to flow 250 HP intercooled.
  17. cool sprite would love something like whats under the sprite in my ke15 :)
  18. another way you could possibly go is 4afe. my mate pete just put one in his ae82 hatch. cost him bugger all for engine, box, harness and computer. someones leftovers from a gze conversion. it goes real good now. seems a lot torquier than the other 4ags i've been in. add turbo. no idea whats involved to drop it in, or what you would do with fuelling and how best to drop the CR. something a bit different.
  19. sounds good. a weber 32/34 DMTT is a blowthru carb. think they came originally on some supercharged lancias, and on certain renault turbo models. http://personal.inet.fi/cool/loser/Carina73.html i have just fitted one on the 4k in my ke15. sc14 to go on soon :)
  20. if you run an early 3k bigport head you may have trouble with this much lift. the early heads have the valve stem seals in the retainer, which sort of reduces the amount of lift available, compared with later heads. if you change to later guides and the valve stem seals that clip onto the guides, it shouldn't be a problem. the 3k bigport heads were standard on later 3k equipped ke10s through ke20s. 3k-b heads have 2 extra water galleries, going into the inlet manifold. the next cam i buy will be a tighe 112 20/60 to go in bec's ke16 which has a stocky ke70 4k-c atm. seems to be the strongest cam up to 7 grand with dyno2000. for street driving torque is good.
  21. ke1x
    4k
    i wouldn't say my motor is nasty, or exotic. just a well matched budget combo, which has had 3 years of fine tuning. my engine is a late dished 4k. i scored it for nothing for helping a guy get a few cars running and tidy his yard. it was a fresh jap import that was put in a car, but they never got running. i took it home opened it up, perfect. all the bearings like new. just nicely run in. i just retorqued it and replaced all the seals. i put in a tighe 113 reground cam. 25/65 65/25 400 thou lift. i also shimmed the oilpump pressure relief spring with a 2mm washer, for extra oil flow and added reliability. also changed orig single row timing chain for double row item. i skimmed the head for 9.8:1 compression (late dished 9.5:1 std). gave the ports a cleanup, nothing flash just got rid of all the casting dags. i paid most of my attention to the valve bowls, gently blending them into the seats forming a venturi . i got a decent 3 angle valve job. i reused the standard valve springs, shimming them for extra seating pressure (be careful doing this, coil bind bends pushrods and strips rocker supports). the headwork cost $100 for the machining. that was, skimming, 3 angle job, and a couple of helicoils on the back of the head. cost $90 for cam regrind, and a little over $100 for the VRS kit and seals. add around $70 for an exchange clutch kit (which i broke in the first 2 months). cost a bit under $400 all up in the car with oil and filter. the rest of the combo comprises a ke70 5 speed, weber 28/36 DCD, scorcher recurved bosch dizzy, pacemaker 4 into 1 extractors, 1 7/8 inch exhaust, and 4.55:1 diff. it goes quite well, and returns good fuel economy, very smooth wide power band. it is lots of fun to beat newer cars off at the lights. especially now with the 4.55 diff. have claimed a couple of v8 victories in the last week. v6's pah! :) just remember that a ke15 only weighs around 730 kg. it's all about power to weight, and gearing. i've just spent more time than money on my setup.
  22. Teddy, i would consult with insurance companies before doing any mods, then talk to an engineer. a young bloke with a heavily modified car is going to have hassles when it comes to finding insurance. it will be expensive. expect to pay $300+ yearly for 3rd party property, $600+ yearly for 3rd party fire and theft. u need insurance, at least to cover the other car if you stuff up. if you can hack the cost of insurance go for it. just something to keep in mind, probably the last thing a lot of people consider when it comes to modding a car. i would recommend joining a car club and doing a few motorkhanas. you will quickly see where money is best spent. handling and consistency is far more important than outright power. just watch fook in pinky or mumblezzz :)
  23. sounds like fun. would love to enter my ke15 in it. would need a navigator though.... Doug
  24. thanks, nice to be here. seems like a pretty cruisy group without to much agro. thought i'd like to get in touch with the local corolla scene, i'm near ipswich. been meaning to update my page for quite a while. way, way out of date. hey nick, fook. sunday was a blast. :D Doug http://au.geocities.com/ke1x/
  25. hi guys. just joined and thought i'd say a little about myself. i'm a confirmed corolla freak, been driving ke corollas for almost 15 years, having owned 7 so far. currently drive a ke15 sprinter with a warm 4k and 5 speed. missus (bec) drives a ke16 wagon with stocky 4k and 5 speed. also have a ke10 which i may do up one day. recently have been getting into motorkhanas out at willowbank (done 3 so far). so much more fun than flogging around on the streets. Doug http://au.geocities.com/ke1x/
