Perthke55
    29
Everything posted by Perthke55
  1. id be interested in a ke55 sedan 1.
  2. Jon i found i could lever certain bits of, as there done with plugs, tho, a few badges had rivet like pins in there, they should be to hard to dislodge
  3. Sounds interesting, ive seen a ke55 with a hemi 6 in it, an that was a very rough fit, but, it went hard.
  4. cheers dude yea i have got em of now, an found evidence of bad repairs by the previous owner :) centimetre thick layer of bog on the left hand side rear quater panel.. :)
  5. ok had a look at the side strip there glued on, so should come of with a bit of care, an the chrome stip that is above the door arches will come of to? These are picks of unusual rust i found on my window arches?looks like a pain in the arse to fix.. sorry if there big an out of focus taken with a camera phone. (pics resized by Tiger)
  6. ok, I'm sure some1 knows how to do this, i want to remove the side strip/trim, an badges on my car, ive heard mixed things like on some models they are glued on some they have clips, what type are the KE models?an whats the best method of removing them? Cheers to the KE experts.
  7. Name- Jamie Ride/s- Ke55 sedan Occupation- Retail MSN- [email protected] Other affiliations- OST(old school toys) Mods current- removed door reflectors, stereo. upcoming/future mods- remove rust, get the body straight, maybe some stitch welding, get suspension right, an paint job, thena 4age+ right gear box+lsd, an then interior retrimmed, custom gauges, an then who knows.. egnine mods probably :D
  8. maybe you could set that up for your newer engine.
  9. sounding nice dude, have u figured out a way to get the bolts to stay in place longer?maybe get a titanium, exhaust of the stock size?an strip the backseats out for weight reduction if you havent already, then see how you fare against the skyline.
  10. this is pretty interesting, so getting a 3k dual chain+tensioner installed?will help with timing?
  11. this is gonna be an interesting beast, can't wait to see the results.
  12. haha mines the stock green, is yours a beige one dan?i think i seen you or another member driving through midland, nice exhaust note to the car. ;)
  13. Ok, this topic is for corrola spottings, you think are interesting, so ill start i keep seeing a silver ke55(squareish headlights style around maddington metro, looks like a respray, so might be a member here?
  14. well at the moment, better handiling an gearing, for a start,i don't drift, i do hills runs, an the better my car handles an accelerates for this the happier i am, i reckon for a 27year old car it goes pretty well. then maybe get the surface rust taken care of, the chrome redone an a paint job, an engine mods/interior/stereo after, i have a cordia turbo available if i want to, tho I'm not sure its such a simple thing to do. I'm going on a cruise next friday, ill try an get some shots of it then.
  15. ok thats quiet informative thanks, an what do u kno about the tail shaft, there supposed to need to some modifaction..?
  16. yea i looked, but your missing my point, i don't know what to do, i never welded before, an fitting it I'm in the same boat, an the pics for it don't load up, I'm asking is for info, an help, as i said, its not something i know how to do yet. :P
  17. well i want to install a r31 4 pinion lsd, but that will be a wider axle an need to be shortened?an installing is also my issue, as i havent done these sorts of things before, an the faq doesnt exactly give much info on how to instal it.
  18. As i said i havent done that sorta stuff before, other people who have done its advice/help/suggestions arewhat I'm after.
  19. Hey dan, Yea mine has the holden suspension so its a bit different to lower, as i here..yea shes a manual, what sort of diff ratios are there, an how do i instal them?i kinda would like to put a r31 lsd in if i could get one, but I'm havent really done that sorta thing so yea..not sure, id also like it to handle better, as i like to do down hill touge runs.
  20. close thread please, cheers.
  21. Ok guys, my bog stock ke55 needs to be upgraded..so I'm open to suggestions, an info on acheiving them, eg installing corona struts? lsd upgrade, brakes, engine, lowering etc, possibly making a customer instrument cluster etc. would post this in the ke forum but id rather put it here, as you guys would be of more help an are local. cheers. Jamie
  22. hey i was wondering if anyone knew were i could get a set of extracors, basically a full exhaust set up for my ke55, also after a side draft weber set up. cheers people.
  23. Perthke55
    Stickers
    hey I'm after a sticker.
  24. Perthke55
    Rolla Pics
    yea that was just after a cut n polish.
  25. bogged ke55 do you still have that exhaust manifold?
