nz_83_dx
    88
Everything posted by nz_83_dx
  1. alarms are pretty simple to install into these old cars, and are reasonably cheep
  2. the MAP (Manifold Absolute Pressure) sensor versions have a small black box that is attached to the inlet manifold by a rubber pipe. (This pipe lets the sensor sample the inlet manifold air pressure) The MAP sensor usually sits on the firewall, and looks like this - The AFM (air flow meter) sits between the throttle body and the air cleaner. The AFM is simply a sprung flap that swings back more and more as the engine sucks more air, thus making more power. looks like this -
  3. omg thats incredible
  4. # <5/89, AE92 Corolla Levin GT-Z. Bigport AFM type, with DLI igntion http://www.toymods.org.au/forums/showthread.php?t=141
  5. http://www.rollaclub.com/board/topic/5644-4age-into-ke70-ae71-conversion-the-step-by-step-noob-guide/
  6. wow that would've been a BIG hit!
  7. Yea its a very simple but rewarding thing to do, only difficult part is securing the actuators and running the wires into the front doors, otherwise its pretty straight forward. Here is where i secured them....... Front Back
  8. 50L.... its all in your car manual
  9. I always go ngk plugs and bosch leads, genuine toyota filter
  10. bit of bog and paint- problem solved..... just a bit dodgy hahahaha
  11. I'm looking at replacing the 4k in my ke70 but have 2 options, a 2TGEU or 4AGE. What would be the best? thank you for your advice
  12. nice, whats your windscreen sticker say? hahaha
  13. here they are....
  14. so far ive installed it in 2 doors, pretty easy- just need to have a bit of an idea of what your doing. heres 2 pics- one of front position, one of back.
  15. ok thanks, did u have any problems setting up motors in the back doors?
  16. hey, I'm looking at buying the central locking kit from repco and was wondering if anyone has any tips or recommendations? cheers
  17. ok sweet, ill go have a look. thanks for that
  18. o i think i know the place- thanks for that! do ya mean 100mm X 100mm? 10mm X 10mm sounds a bit small hahaha
  19. ok. do you reckon you could upload a pic of the seal? we don't have a Clark Rubber in nz Cheers
  20. so true
  21. hahahaha nice. does it leak when it rains? or did u seal around the stockings
  22. wow this is looking good. did u use spray tint on the tail lights? or just stockings?
  23. does anyone know which wire in the ignition to connect the immobiliser wire to in a ke70? thanks
  24. hi, i can pick up a ae92 trueno front seat cheap- is it able to bolt up to ke70 easily? with abit of minor modification? thanks for your help
  25. sweet thanks, any tips on getting the gauge cluster out?
