kurts1
    47
kurts1's Achievements
  1. Hi guys, I am running a stock 4age coil with hyperpak ignition computer... I am just wondering if i have to use the factory ignitor with this set up? Thanks P.s. i am getting 12 volts out of the coil but wondering if it makes ant difference to use the ignitor? Cheers
  2. Yea its still on carbs... I'm just guna trace the wires back and see how i go! Cheers for help!
  3. Hey guys... I'm currently wiring up my 4age conversion into my ke70... I have extended the positive and negative wires onto the opposite side as the dizzy is on that side... my problem is that when I put a test light on them and turn the ignition on i get no light turning on... hmmmm Is there a possibility that the ignition relay or fuse is broken? or i currently have my dash out.. could there be a connection in the wiring loom/harness that is disconnected at present? Any help would be appreciated! Cheers
  4. What does everyone think about these wheels for the rear? Pretty keen Old school volk mesh!
  5. Valves all lapped up! Should have engine all built up by the weekend !
  6. You probably could mod them maybe? it looks like the back could pull away from the glass but not sure... they definitely look good though
  7. You can replace the bulb... the bulb that does normal beam has its high beam filament blown so the lights are sweet until you go to put on your high beams then in switches the inside one on and the outside on off.. so i figure its best for a fresh start!
  8. Yea guna rust proof all up there so will end up being a black colour!
  9. Let me know what you guys think and ideas I'm allways looking to improve things! Thanks
  10. Cams,, Carbs
  11. 4age...
  12. How the quads look... Still need to put Chrome bumper on... Number plate just zip tied for testing out suspension!
  13. Wheel fitment..
  14. Got T3 power steering arms... Heres the lock!
  15. How the car sits now... The lights are out as of changing the bulbs..
