woteva
    84
Everything posted by woteva
  1. Hi Glenn I think that you bought my pedal box? Join up here: https://www.facebook...ADLCorollaClub/ and ask, someone will be keen to help.
  2. Sorry, I have never bought any from there, so I didn't know this, but I think that you can get metal ones on ebay too, they should be ok.
  3. http://www.ebay.com.au/itm/79-84-TOYOTA-COROLLA-KE70-TE71-TE72-WINDOW-WINDERS-HANDLE-CRANK-BLACK-/110848916313?pt=AU_Car_Parts_Accessories&hash=item19cf1c3b59
  4. It is a 1981 Kos Kruiser it is 26". I have two of them, and I just bought the 2012 Kos Kruiser as well. http://www.mongoose.com/aus/2012/2012-kos-kruiser A.
  5. Hi Chris. I have a Liteace too. A.
  6. Do these carburetors have electric cut out solenoids on them? are they connected?
  7. I need to know about this too. Will a 5K electronic distributor work on a 7K-C or 7K-E, someone mentioned to me that the 7K distributors have a longer shaft? Thanks, A.
  8. I have had this problem before, I swapped carburetors, mucked about with vacuum lines, etc. ended up tightening the intake manifold and that fixed it. A.
  9. woteva
    Spotted
    Spotted flat front, white, KE70, with quadlights, pulling in to Shell O.G. Road about 11:30 this morning. Anyone here? A.
  10. Here's one on eBay: http://www.ebay.com.au/itm/TOYOTA-COROLLA-KE30-35-CORONA-RT100-FUEL-CAP-KEY-oa-/310322078741?pt=AU_Car_Parts_Accessories&hash=item4840a32415 A,
  11. Depends on what you call easy, you will need a press to remove the old bearing from the axle, and again to install a new one. A.
  12. You may need another clutch, if the spline count is different on the K50. A.
  13. If you are thinking of making Caltracs this may be of some help: http://www.hotrodsandhemis.com/traction1.html http://www.hotrodsandhemis.com/Traction.html W.
  14. Ethanol is the stuff that you drink in beer, wines and spirits. http://en.wikipedia.org/wiki/Ethanol I can't find any factual reference to it being corrosive or it being a solvent to any of the plastics, or rubber that is used in automobile fuel systems. Apparently plastic fuel tanks are made of polypropylene and this chart says that polypropylene is ethanol resistant: http://www.vp-scientific.com/polypropylene%20properties.htm There are references to it being a problem on the web though: http://www.google.com.au/webhp?rls=ig#sclient=psy&hl=en&newwindow=1&safe=off&rls=ig&site=webhp&q=ethanol+and+plastic+gas+tanks&aq=1&aqi=g3&aql=&oq=&pbx=1&fp=9ee942b6aec5b84d Maybe the problems occur when it is mixed with hydrocarbons? There are problems with ethanol attracting and mixing easily with water, which is corrosive to metal engine parts and fuel tanks, lines, etc. Over the years I have had water in my fuel tanks a few times, if there is not too much in there, I have added methylated spirits to the tank to mix the water with the fuel. These days methylated spirits is not methyl alcohol but ethyl alcohol, another name for ethanol In the U.S. they have E85 which is 85% ethanol fuel. W.
  15. I have bought second hand tyres from this mob before, sometimes they are as good as new, but much cheaper, worth a try anyhow. http://usedtyremart.com.au/ A.
  16. woteva
    Upi Spotted
    I needed one recently for my slant front, UPI Elizabeth only had a couple of mangled ones. I paid full price for a bent one with the plastic off it ($66.00) had to straighten out the steel part, and screw the plastic bit back on with stainless steel screws. It turned out ok but, you might be better off trying regular wreckers. A.
  17. Haha cool, I hope that it solves your troubles. May I ask what they charged for it? A.
  18. At U-Pull-It Elizabeth, in the back of an old Lite-Ace van, in the rocker cover, is a complete 5K rocker assembly. I saw this there on Sunday, if it's any help? A.
  19. Excuse my ignorance but what is a "ca"? Thx A.
  20. I am restoring a couple of Kos Kruisers, 26" BMX from the early 80s
  21. Owner:Aaron Username:woteva Location:Campbelltown S.A. Vehicle Name:---------- Vehicle Model:KE70 Body Shape (# Doors):Station Wagon (5) Date Made:--/81 VIN:KE70-W-9001596 Colour:Red Engine:4KC
  22. woteva
    Spotted
    Waved to a bloke in a tidy looking esev with a grey primer bonnet at the Lower Portrush Road Marden intersection, you waved back, anyone on here? I was in my blue wagon. W.
  23. I gave you the torque settings from the Original Toyota manual here: http://www.rollaclub.com/board/index.php?s...st&p=415404 I don't understand why there would be any debate? Cheers, Aaron.
  24. My original manual says: Oil pan x Cylinder block Standard bolt 0.2-0.4 kg-m 18-34 in.lb Step bolt 0.3-0.7 kg-m 27-60 in.lb Cheers, W.
