KeTen
    35
About KeTen
  • Birthday 07/22/1979
Contact Methods
  • Website URL
    http://
  • Location
    Sydney
  • Real Name
    Greg
Recent Profile Visitors
5428097 profile views
KeTen's Achievements
  1. I've got a ke70 radiator In mine. I only had to make two tabs to fit the wider radiator then use ke70 lower hose.
  2. With the lever pulled out its just a normal 3 speed manual with engine braking With lever pushed in it will go into overdrive in 3rd gear when you back off the throttle. The revs will drop off just like you have put it in 5th but with this set up you can just use it like a kickdown in a auto give it gas and it will change back to 3rd for you. Just drive it more and you will figure it out Greg
  3. You turn it on by pulling the lever under the dash with ( O ) on it Out is off in is on Greg
  4. I got this from crown thread on toymods My mate has it in his '64 rs46 Wagon i've got a '66 wagon with no overdrive Put some photos up on there if you want There is a lot of good information in that thread its a good read http://www.toymods.org.au/forums/showthread.php?t=481&page=33&p=725302&highlight=overdrive#post725302 Had one of these in my first crown. 1. with overdrive button in all the time freewheels--got great fuel economy once I realised and took foot off accelerator when on long downhill runs etc. 2. with overdrive button in only needed to use clutch starting off in first, any other change take foot off accelerator briefly change gear then put foot down again (no need to put clutch in). 3. with overdrive button in, hit accelerator hard and it will kickdown as autos do, used to kick down and hold second until past 60 mph. overall one of the most fun setups I had driven Greg
  5. FAQ link isn't working? any help would be great. Thanks Greg
  6. I had ke30 2speed auto in my ke10 then changed to ke70 5speed it used the same yoke if that helps.
  7. Ha Ha that's my motor. Very easy conversion for a ke10 i finished mine in less than two weeks. Best thing i ever did.
  8. His website is www.dwarfcarpromotions.com he uses corolla parts for a lot of them.
  9. Nice find they are rare i have a ms46 wagon good luck with rebuild. Some inspiration look up crown picnic mooneyes for more pics Do you have all the trim parts ? Greg
  10. This guy has amazing skills check out the link http://www.varietyvideosllc.com/about2.html Ha ha fridge dash
  11. Hey saw you beat that red 1200 ute at jamboree on Sunday do you know Luke Coy Oldest ke10 i have seen Frame number 17xxxx
  12. Those photos are great thanks Got the motor running today and made a ke20 exhaust fit with some old extractors i had out the back Greg
  13. Thanks Heaps
  14. I mean a photo of inside the rear panel where the lock is bolted to the tail gate, If you can with out to much trouble the out side would be ok. Have you replaced the rear shocks on your wagon because we don't have any and are having trouble finding the part numbers? Greg
  15. Hey my mate bought a ke16 with out a fuel tank and no locking parts like latches . I need photos of the tank ,spare tire hanger ,tailgate locks and where the rear seat locks in . I think ke26 parts are similar from photos that i found searching the site Any help would be great Thanks Greg
