Carts
    17
Everything posted by Carts
  1. Hi all I have a ke25 and want to up grade front swaybar and I can't find one. I was told that a TA22 bar will fit my car and I believe that it is 22mm bar that would be perfect. Can anyone tell if this will work or not.
  2. It will clear the x member i think its just is the oil pickup position and it sounds like its the same.(great). thanks boys.
  3. Hi all Can some one tell me if i need to change my sump on a 100kw 4age when coverting to RWD if so will a 4ac sump do.
  4. Thanks for feed back. Dayley drive + 205 tyres and may be a track day from time to time. I know the brakes are not great on the rear but i have an r31 diff for it but the cost to convert it to 1320mm is $800 to $1000 and it all seems to be an over kill.
  5. Hi all Will the standard ke25 diff handal a 100kw 4age. Has some one try to do this as the body weight is only 850kg. How long will it last? :hmm:
  6. I think this is my only option thanks guys
  7. You use two short axles in both sides but it still ends up at 1410mm total and offset diff center. So maybe shorten shorten one side more will get the center closer to where should be and give me 1320mm Thanks that will work better and should cost me about $750
  8. Thanks for the info but i still hoping for a diff with the magic 1320 mm disk to disk. To do the r31 diff it will end up to wide as the wheels only 20mm - offset. I must use these wheels because they look great and where free.
  9. Can someone help me I have a ke25 and need 114.3 PCD with disk brakes and about 4.11 to 1 ratio or 3.89 and max width of about 1300mm setup for 100kw engine. What diff can i use. R31 bw78 can only be shorten to about 1370mm need to do about 1300mm to fit deep dish wheels that look great old school. R31 diff to get 1300mm need to shorten axles gets to mutch cost. can someone please help me. Carts :huh:
  10. The 20v silver top.
    How many km on it,
    Is complete runner,
    Has it a ECU wiring loom with it.
    Is it in a car.
    What is needed to make it run.
    Read more
  11. It has 51mm x 45mm 38mm spigot
  12. I have a 1971 ke25 and just fitted ae71 t50 gearbox std jap banjo diff what drive shaft can i use. Ke25 has external clips t50 has internal clips on drive shaft. Is there a shaft that i can use. Can some one shed some light.
  13. Hi Are they still in good working order and did you run them on a 4age and what distributor did you run. If they are running condition. I will take them if you have them still them. Please tex me on 0400018371
    Read more
  14. The diff ratio is 3.89 to 1 barner Warner
    Read more
  15. Think I will have a look at some remote shifter from other cars and vans to see what sort or clearance is required.
  16. Thanks this is a great help. I will have to do a measure up and i was thinking there are a lot of cars with remot shifters that may be worth looking at.
  17. does some one know if a 3sge beams with 6 speed fit in a ke25 corolla
  18. Thanks for your help I found it and it is Peak White
  19. Thanks you for that i have look high and low. this is great.
  20. Can some help me with paint codes for my 1971 ke25. The car ID plate has no paint code. I am insterested in white. :jamie:
