libbor
    21
Everything posted by libbor
  1. Yes I have darren 0433 490 497
  2. Gday Pete Another problem with adjusting the angle of the engine is the carburettor angle will be out. If you did go ahead with uprighting you would need an angled carby base which would make the carby sit level again Cheers, Darren
  3. Yes mate , got a good one, $50 Its already out of the car Darren 0433 490 497
  4. Do you still have the auto stuff?
  5. i have a good one. I'm in Canberra if thats any help Darren
  6. Yes I have one. Was running fine when I pulled it out $150 Darren 0433 490 497
  7. Well there you go. Its a small world isn't it
  8. I am Andrew. Why, Do you know me?
  9. I own A & D Automotive Services In Fyshwick and am happy to offer a 20% discount of my labour rate and a trade discount off all parts. I also have many second hand parts for ke55 and 70 series corollas Our phone number is 02 6280 9911 301Canberra Avenue Fyshwick ACT www.adautomotive.com.au If this post contravenes any rules please delete it but it is an honest offer Cheers Darren
  10. I was driving down a street in Kaleen the other day and there is a ke coupe sitting out the front with grass growing up its side. Does anyone know who owns it? It looks like its dead. If it needs a new home I might be able to help Cheers Darren
  11. I have a ke55 in disguise. It sounds like a corolla, looks like one underneath, goes like one, but its a Morris Minor with a 7KE engine, k50 Ke55 diff. Ke55 front discs, Ke 55 booster and master Cylinder. Do i qualify to be included in your cruise? Darren
  12. James Did you end up selling all your parts? Darren
  13. Thanks mate I have just come back on and I didnt realise I had double posted . Can the mods delete the 1st one Yes its a good engine but he may have already found one. As of today I still have it Cheers Darren
  14. Is a Ke55 switch the same? If so I have a couple of them in really good condition Darren
  15. I have one if you still need one its a 4k Runs well $275 Darren 0433 490 497
  16. Double post by mistake Sorry
  17. If you do manage to separate them you will never get them back together. If you have no other option i would cut the shifters down the bottom in the thin section before it goes inside the thick piece. I would mark both shifters with a texta before you cut so you get the alignment right. Then sit the thick end in a tall cylinder filled with water to keep this section cool and then weld the two halves together. It does work, I have done it before.
  18. Hello all I'm after some info about a 2t gearbox Is there a shim that goes between the snout and the input shaft bearing Doea anyone have an exploded diagram of the gearbox Cheers Libbor
  19. thanks guys ill give it a go Darren
  20. Hi Rolou, Do you still have the auto box? is it a 3 or a 4 speed Cheers Libbor
  21. Hi all, Has anyone here attempted a gearbox rebuild on a 5 speed from a ke70. If yes, was it hard and is there a step by step sticky here anywhere that i may be able to look at I just have noisy bearings. its whining in 1st, 2nd & third thanks Libbor
