nesta
    13
  • Location
    brisbane/ Hillcrest
Recent Profile Visitors
6155530 profile views
nesta's Achievements
  1. I did get the carb rebuilt and re bushed the shop that did the work on it i told them that I was doing a blow thru turbo I don't know what they did to prep it. But I do know that it has a vent at the top so I can see some The fuel bowl that's about as much I know about it they said it would be fine for blow thru. I'm still learning about it all from reading people post. On here
  2. Hey I need some help with my blow thru 4k I'm using a Holley 180 problem I'm having is when I just crack the throttle it starts to run really rough if I keep going it stalls but if I wind the mixture srew right out it doesn't run rough down low but it runs rough up top. Hope some can help me out with this. Problem. Cheers
  3. I have read somewhere on here that they use ke35 but I'm unsure of the difference between 30 and 35 boosters
  4. Hi guys I need some help I have done the xt130 struts in to my 74 ke 30 I am only running the girlock brakes the booster on my car has a small booster and I fitted the pager master jb 1765 I think and there seems to be a small gap where the master bolts on so when I hold the brakes on at the lights it runs rough is there another booster that will fit in the 30 and mount good for the pager master. Cheers
  5. mm the wheel spins ok with no noise doesnt seem to be hiting the caliper took it for a drive and all worked ok
  6. i hope not but .i also for got to say that was with my mags and if i put the standard xt130 wheel on it seems to sit ok
  7. hi guys i'm wondering if some one could help me out i've just finished installing xt130 struts and brakes on my ke30 everything fitted well but when i put my wheels on the drivers side sat ok but the passenger side wheel is sticking out a bit it looks like it has a bit of positive camber i am using the steering arms of the xt130 and both wheels ar the same so i'm unsure whats going on hope some one will be able to help me thanks
  8. hi guys i'm wonder if some one could help me out i'm going to do the xt130 struts and corona calipers, i'm using the sumitomo calipers but what i need is the the parts that hold the pad pins in they are some sort of clip and spring? i have tryed to goole it but with no luck if anybody could tell me where i might be able to buy them in brisbane that would be great or if i could go to the wreckers and get them from another car as there is not many xt130 around cheers Adrian
  9. ok cool thanks heaps for that i will have to head down to the wrecker tomorrow would you know what sigma control arms i will need gh,gj gk? also can i use the corona spring and just change the top of the strut i don't mind if the front sits a bit high if i'm using the 141 struts what steering arms will i need?
  10. if i used the st141 and fit sigma lca wouls that help to pull the camber in?
  11. hi guys i'm wanting to upgrade the brakes on my ke30 i read on faq that you need the corona xt130 but could i use the struts and brakes out of a 85 corona st141? as i went to a few wreckers in the bisbane southside today and only found st141 models cheers
  12. ok thank you for that
  13. hi all i'm new to the rolla club i just bought a ke 30 corolla but my carby is stuffed does any one in the brisbane area have a standard carby that works that they could sell to me as i need to get my roadworthy tomorrow so i can get to work next week you can contact me on 0427261550 or 38069570 than you Adrian
