hey guys
as you might know I'm building a 4agte ae71.
i was just wonderin what it takes to bolt a turbo onto a 4age. ive got the oil and water lines and the mechanical side figured, but I'm just a bit stumped on what to do about the effects of boost on the map sensor and the ecu. i have read that a simple 1 way valve sliped into the map sensor line will allow me to run boost wich will stop the map sensor from reading above atmospheric pressure. Also, i was going to run a razorback ecu. any thoughts?
also wonderin where to put the brake booster vaccum line. can't put it on the intake manifold as there isnt vacuum there but boost. can't think of where to put it?
