Trent-KE30 Posted March 24, 2006 Report Posted March 24, 2006 G'day, Just a quick question just wondering where to buy lowering blocks for a KE30? I tried ebay and a google search but to no avail? Surely someone has blocks in there KE30 please let me know if you do and where you got them, Cheers Trent Quote
Rolla__Boy Posted March 24, 2006 Report Posted March 24, 2006 Lowering blocks are bad!!! Either pay someone to reset your leaves, which is relatively cheap, or flip one or two over. Quote
Trendact Posted March 24, 2006 Report Posted March 24, 2006 As Goeff said just get your local suspension place to reset your springs or they should be able to sell you the blocks. You may find that the cost of the blocks + long U bolts we be very close to having the springs reset and a lot safer. Quote
Raven Posted March 24, 2006 Report Posted March 24, 2006 Flipping leaves over requires a rattle gun due to rusted bolts most of the time. Which leaves do you suggest to turn over? Cos i thought turning over leaves would raise the height of the vehicle in question. Quote
Trent-KE30 Posted March 24, 2006 Author Report Posted March 24, 2006 Yeah was originally getting the leaves reset but just testing the waters, Thanks will get a quote next week, Trent Quote
Dan Posted March 24, 2006 Report Posted March 24, 2006 (edited) http://www.burnincustoms.com/content/view/11/14/ From my knowledge lowering blocks are quite generic, as well as the extended 'U Bolts' needed to make it work. That said, it would be preferable to flip a leaf or two or get them reset; it will make a safer more comfortable ride. Lowering blocks are dodgy. That said, once you've sorted out what the go is with them, let us know so I can put some on the sedan :P. They are advertised on Burnin Customs for between $40-$80 for a kit including extended U bolts etc. They range between 1" and 4". Also, it is said on that page that they will reset springs for $300 :|. Not good news, to me anyway. Dan. Edited March 24, 2006 by Dan Quote
Rolla__Boy Posted March 24, 2006 Report Posted March 24, 2006 Flipping leaves over requires a rattle gun due to rusted bolts most of the time. Which leaves do you suggest to turn over? Cos i thought turning over leaves would raise the height of the vehicle in question. Flipping leaves over does not require a rattle gun....it requires some vice grips, a 13 mm spanner and a G clamp... And if you flip the smallest and second smallest leaf, it puts the car at the height of ALL the ones I have lowered and put pics of up on this site. I have lowered probably 10 corollas using this method, and do not own a rattle gun. Quote
Raven Posted March 24, 2006 Report Posted March 24, 2006 As i did say and do quote "most of the time". I didnt say they all require it and i've seen some pretty rusted leaf springs in my time, but i will give this a shot when i lower the front of my car :P Quote
Rolla__Boy Posted March 25, 2006 Report Posted March 25, 2006 As i did say and do quote "most of the time". I didnt say they all require it and i've seen some pretty rusted leaf springs in my time, but i will give this a shot when i lower the front of my car :P But you are completely wrong with most of the time....I have flipped lots and lots of sets of leaves....and ALL of them have been rusty, and never once had to use a rattle gun, in fact if I had used a rattle gun, all it would have done is snapped the bolt. As it is by hand the bolts often snap. I have lowered my KE30, my friends KE30 twice, and my friends KE55 all in the last 6 weeks, and not needed a rattle gun....so that would definately not qualify as most of the time. Quote
oh what a nissan feeling! Posted March 25, 2006 Report Posted March 25, 2006 Dare i say it, flipping of leaves is a great and very cheap way to lower your car, but certainly does not help the handling. it makes it a little bouncy. Go for the spring reset, it cost me $80, at allset springs, and it even included a dodgy pressure pack paint job! whoohooo! Quote
Raven Posted March 25, 2006 Report Posted March 25, 2006 But you are completely wrong with most of the time....I have flipped lots and lots of sets of leaves....and ALL of them have been rusty, and never once had to use a rattle gun, in fact if I had used a rattle gun, all it would have done is snapped the bolt. As it is by hand the bolts often snap. I have lowered my KE30, my friends KE30 twice, and my friends KE55 all in the last 6 weeks, and not needed a rattle gun....so that would definately not qualify as most of the time. Maybe YOU have success, but everyone isnt YOU dude. So don't go implying that just because you've successfully flipped springs means that me or anyone else that has attempted it is "completely wrong" because I'm the one that was doing the work, not you :P Quote
Rolla__Boy Posted March 25, 2006 Report Posted March 25, 2006 You are wrong in making people think that you HAVE to have a rattle gun to do it, because you just don't Quote
ScottKE1X Posted March 26, 2006 Report Posted March 26, 2006 I know here in SA, few years ago, lowering blocks could be bought from Motormate for $80 or so. not sure if you have motormate interstate. I have pulled 1969 leaf packs apart without a rattle gun. I have reset leafs in my ke30 cost $300 including an extra leaf. I must admit tho I'm not 100% happy with them as not they sit dead flat and don't provide the best ride. My ke11 has extra leafs added ontop of the normal pack with one or two flipped. This lowered the car enough and stiffened it aswell but skips quite a lot around corners (good fun tho :P ) got 7 leafs in there now, little overkill i think. Soon i plan on getting a standard leaf pack, removing a leaf or two and adding small lowering blocks. then running stiff sway bars and some sort of anti tramp. Be a bit of an experiment. all in my ke30. my 2c Scott. Quote
SLO-055 Posted April 11, 2006 Report Posted April 11, 2006 the best way i've come across so far is to take the top leaf with the eyelet, get it flipped over (so eyelet faces opposite way to before, which would be down) then get that one reset, that gives a couple of inches, and doesn't give you bad bad axle tramp like most of the other ways, an anyone with half a clue will figure out the tools they require as they set off into the job, i'm sure there are people that have pulled leaf packs apart with their teeth... 1 Quote
