hey
does anyone have the part number for dellorto DHLA40 carbies?
mine is leaking fuel, my local parts store said they can get the kit but can't find them it in any books
cheers andrew
Also try recarb in canberra i think ,good guys and no there carbs .Sorry don't have a number but they sell a lot of kits on ebay as well.
Mostly weber but do dellortos to.
ok got it sorted and got them rebuilt
but it leaking fuel after i turn it off
what do you guys do about fuel return, thinking it might be getting to much pressure and pushing the fuel thought the carbies
Leaking from where? As in out the throats?
You DEFINITELY need to run a fuel pressure regulator on these things, stock K engine pumps will put out more than 4psi which is the absolute max for these things
Go get a holley red FPR and a cheap gauge.
These are pics of mine, I mounted the FPR off the manifold-carb bolts on an aluminium angle bracket. Gauge is downstream before the carbs, but I'm going to remount it onto the spare port on the FPR... One day.
Edited by philbey
I am going to run a mitsuba pump on both my 2TG and K-B. You can get Malpassi filterkings cheap from Canada (about $USD70 inc post).
These act as a fuel filter and a pressure regulator for carbed engines.
http://cgi.ebay.com/ebaymotors/Malpassi-Fu...n%3D5%26ps%3D63
Excuse the link. I have bought two of these from this seller.
Have had personal experience with over pressuring the needles on twin webers on an L20B. Did a great job of washing the bores. I don't recommend it
Any speed shop will have them, just look for a holley red Fuel Pressure regulator.
I can't remember what the top end pressure is on it but it's well beyond 4PSI. You'll need a gauge too.
