General Specifications
(Redirected from User talk:GJM85)
Jump to navigation
Jump to search
Toyota Corolla Ke2# 1970-1974 Specifications
| Carburettor | 3K | 3K-B |
| Throttle Bore | 28mm | < |
| Fuel Pump | |
| 3rd | 1.383 | 1.384 | N/A |
| 4th | 1.00 | 1.00 | N/A |
| Service Data | |
| Fan belt deflection | 8 - 12mm |
| Spark plug gap | 0.8mm |
| Distributor | |
| Points gap | 0.45mm |
| Dwell Angle | 46* |
| Condesor Capacity | 0.20 - 0.40mf |
| Ignition Timing/Idle Speed | |
| 3K | 8* BTDC @ 600rpm |
| 3K-B | 10* BTDC @ 650rpm |
| T | 10* BTDC @ 600rpm |
| Valve Clearance | |
| 3K & 3K-B | Intake - 0.20mm |
| Exaust - 0.30mm | |
| T | Intake - 0.20mm |
| Exaust - 0.33mm | |
| Steering Alignment | |
| Toe In | 1 - 5mm |
| Camber | 1.5* |
| Caster (Wagon) | 1.4* |
| King Pin Inclination | 8* |
| Capacities | |
| Fuel Tank | |
| Sedan & Coupe | 45 litres |
| Wagon | 40 litres |
| Engine Oil | |
| 3K & 3K-B | 3.3 litres |
| T | 3.7 litres |
| Engine Coolant | |
| 3K & 3K-B | 5.3 litres |
| T | 6.4 litres |
| Transmission Oil | |
| K40 4 speed | 1.7 litres |
| T40 4 speed | 1.5 litres |
| Automatic | 4.5 litres |
| Differential | 1.0 litres |
by GJM85
