General Specifications
Jump to navigation
Jump to search
Toyota Corolla Ke2# 1970-1974 Specifications
| Wheel Track (rear) | 1245 | < | < |
| Carburettor | 3K | 3K-B |
| Throttle Bore | 28mm | < |
| Fuel Pump | |
| 3rd | 1.383 | 1.384 | N/A |
| 4th | 1.00 | 1.00 | N/A |
