Tech:Engine/K-Series/TRD
Link by Taz_Rx
Transcription
The aim of this transcription has been to faithfully reproduce a textual version of the historic TRD manual. Please DO NOT edit this except for correcting transcription errors. If you wish to comment or expand on sections of the TRD manual, please copy them to a new page and do so there.
People are encouraged to check any measurements or part numbers against the original manual in case of transcription errors.
Stage I
(1) Main modifications
- a. Cylinder head gasket.
- b. Piston
- c. Piston rings.
(2) Required parts.
| Description | Qty. |
| Gasket,cylinder head | 1 |
| Ring set, piston | 4 |
| Piston w/pin | 4 |
(3) Assembling standards.
Stage II
1. PISTON & PISTON RINGS
(1) Main modifications.
- a. Piston
- b. Piston rings
(2) Required parts.
| Piston w/pin | 4 |
2. VALVE MECHANISM
- a. Camshaft
- b. Valves
- c. Valve springs.
(2) Required parts.
Replace with the above parts.
3. INTAKE & EXHAUST SYSTEMS
- a. Intake manifold.
- b. Exhaust manifold.
(2) Required parts.
(3) Assembling procedures.
- a. Carburetor.
- b. Accelerator linkage.
(2) Required parts.
STAGE III
1. CYLINDER HEAD
- Caution
(2) Required Parts.
- Caution
- Caution
- d. Port grinding.
- Intake.
- Exhaust.
- Combustion chamber capacity
- As a unit - 22 ~ 23 cc
- When assembled - 31 cc
- f. Water jacket machining.
- Caution
2. CYLINDER BLOCK
(2) Required part.
- a. Surface grinding.
- Cylinder block top surface
- Warpage allowance - 0.02 mm
- b. Boring.
- Caution
3. PISTON & PISTON RINGS
- a. Piston
- b. Piston rings.
- c. Piston pin.
(2) Required parts.
| Item | Sports parts | |||
- c. Piston pin.
| Piston pin bore mm |
| Piston pin outer diameter |
- Caution
- d. Piston rings.
| Compression
ring |
| No. 1 | No.2 | |||||
- Caution
====(1) Main modifications.
- a. Connecting rod.
- b. Crankshaft.
- c. Flywheel.
(2) Required parts.
- b. Crankshaft.
- c. Flywheel.
- Crankshaft x flywheel
- Caution
5. VALVE MECHANISM
- a. Camshaft.
mm |
Valve clearance
mm |
Cam top center | ||||
| A | B | C | D | E | F | |||
EX:0.38 |
106 | 109 |
EX:0.35 |
110 | 110 |
EX:0.4 |
106 | 114 |
EX:0.3 |
104 | 110 |
- b. Valves.
| IN | EX | IN | EX | |
- c. Valve springs.
| Item | Outer | Inner |
- d. Valve spring retainer.
- e. Valve stem pad.
- f. Rocker support.
- g. Rocker arm spacer
- h. Push-rod.
- i. Valve lifter.
- Reference
(2) Required parts.
| 10 | 90072-72661
90072-72681 |
Pad, retainer | 8 | "O" |
- Caution
- b. Valves
| Item | Sports parts | ||||
| Face contact width mm |
| (limit) mm | 0.08 | ||||
- Caution
- c. Rocker support.
- d. Valve lifter.
6. LUBRICATION SYSTEM
- a. Oil pump
- b. Oil pan.
- c. Oil strainer.
- d. Oil cooling system.
| 10 | Clamp | 6 | ||
| 14 | Hose, oil cooler | |||
- a. Oil pump.
- b. Oil filter.
- (Refer to Fig. 14)
- Caution
7. INTAKE & EXHAUST SYSTEMS
- c. Manifold stay.
(2) Required parts.
- c. Manifold stay.
8. FUEL SYSTEM
- a. Carburetor.
| Item | Specification |
| Small venturi | 8011-1 |
| Main jet size | 160#~200# |
| Air jet size | 180#~220# |
| Emulsion tube | ET7772-2 |
| Idle jet side | 50# |
| Pump jet size | 33#~ |
| Needle valve size | 170# |
| Fuel level height | 8.0mm |
| Air horn length | 50mm |
- b. Fuel pump & filter.
| Rated voltage | 12V | |
| Rated current | 2.3A |
(2) Required parts.
DHLA45 x 2 |
- Caution
9. ACCELERATOR LINKAGE
(2) Required part.
- a. Distributor.
| Weight kg | 0.7 | 1.1 | |
- b. Alternator pulley.
- c. Cooling system.
(2) Required parts.
- Ignition timing
(2) Required parts.
Service Standards
Cylinder Head
| Item | S. T. D | Racing specification | ||||
| Bottom surface warpage limit mm | 0.10 | 0.05 | ||||
| Valve seat | Contact surface angle | 45° | 45° | |||
| Contact surface width mm | Intake | 1.4 |
| Exhaust | 1.5 |
Cylinder Block
| Top surface warpage limit mm | 0.05 | 0.05 | |
| Valve lifter hole boremm | 20.000~20.021 | ← | |
| Cylinder | Bore mm | 75.00~75.05 | 79.03~79.08 |
| Wear limitmm | 0.2 | 0.06 | |
| Taper, roundness limitmm | 0.02 | ← | |
| Cylinder bore differencemm | 0.05 | ← | |
| Liner | Fitting allowancemm | 0.055~0.15 | ← |
| Fitting loadkg | 2000~3000 | ← | |
Piston, Piston Pin, Piston Rings
| Piston Diametermm | 74.97~75.02 | 78.96~78.98 | |
| Clearance between cylindermm | 0.03~0.05 | 0.07~0.10 | |
| Piston pin fitting temperatureC° | 70~80 | 80 | |
| Piston ring gap | Compression ring No.1 No.2 mm | 0.15~0.35 | ← |
| Oil ringmm | 0.015~0.06 | ← | |
| Clearance between ring & groove | Compression ring mm | 0.015~0.06 | 0.03~0.05 |
| Oil ring mm | 0.015~0.06 | ← | |
| Piston pin outer diametermm | 17.999~18.011 | 20.005~20.017 | |
Connecting Rod, Bearing
| Bend limit (per 100mm)mm | 0.05 | 0.05 | |
| Twist limit (per 100mm)mm | 0.15 | 0.05 | |
| Large end thrust clearance | Limit mm | 0.3 | 0.3 |
| Specified mm | 0.110~0.214 | ← | |
| Clearance between | Limit mm | 0.05 | 0.05 |
| Specified mm | 0.004~0.008 | 0.009~0.014 | |
| Bearing oil clearance pin & bore | Limit mm | 0.10 | |
| Specifiedmm | 0.024~0.048 | 0.04~0.06 | |
Crankshaft
| Bend limitmm | 0.03 | 0.02 | |
| Thrust clearance | Limitmm | 0.3 | 0.3 |
| Specifiedmm | 0.04~0.222 | 0.06~0.15 | |
| Taper, roundness limitmm | Less than 0.01 | ← | |
| Journal diametermm | 49.976~50.00 | ← | |
| Journal oil clearancemm | 0.016~0.040 | 0.05~0.07 | |
| Crankpin diametermm | 41.976~42.000 | ← | |
| Crankpin oil clearancemm | 0.024~0.048 | 0.04~0.06 | |
| Thrust washer widthmm | 2.43~2.48 | ← | |
Timing Chain, Sprocket
| Deflection limit (load 10kg)mm | 13.5 | ← | |
| Vibration damper thickness limitmm | 7 | ← | |
| Tension plunger head thickness limitmm | 12 | ← | |
| Camshaft timing sprocket wear limitmm | 113.8
(Measure diameter w/chain installed) |
| Crankshaft timing sprocket wear limit | 59.4
| Chain deflection limitmm | 272.7
(load 5kg) |
2 pages of tables to go...
