Tech:Engine/K-Series/TRD
Link by Taz_Rx
Transcription
Stage I
(1) Main modifications
- a. Cylinder head gasket.
- b. Piston
- c. Piston rings.
(2) Required parts.
| Description | Qty. |
| Gasket,cylinder head | 1 |
| Ring set, piston | 4 |
| Piston w/pin | 4 |
(3) Assembling standards.
Stage II
1. PISTON & PISTON RINGS
(1) Main modifications.
- a. Piston
- b. Piston rings
(2) Required parts.
| Piston w/pin | 4 |
2. VALVE MECHANISM
- a. Camshaft
- b. Valves
- c. Valve springs.
(2) Required parts.
Replace with the above parts.
3. INTAKE & EXHAUST SYSTEMS
- a. Intake manifold.
- b. Exhaust manifold.
(2) Required parts.
(3) Assembling procedures.
- a. Carburetor.
- b. Accelerator linkage.
(2) Required parts.
STAGE III
1. CYLINDER HEAD
- Caution
(2) Required Parts.
- Caution
- Caution
- d. Port grinding.
- Intake.
- Exhaust.
- Combustion chamber capacity
- As a unit - 22 ~ 23 cc
- When assembled - 31 cc
- f. Water jacket machining.
- Caution
2. CYLINDER BLOCK
(2) Required part.
- a. Surface grinding.
- Cylinder block top surface
- Warpage allowance - 0.02 mm
- b. Boring.
- Caution
3. PISTON & PISTON RINGS
- a. Piston
- b. Piston rings.
- c. Piston pin.
(2) Required parts.
| Item | Sports parts | |||
- c. Piston pin.
| Piston pin bore mm |
| Piston pin outer diameter |
- Caution
- d. Piston rings.
| Compression
ring |
| No. 1 | No.2 | |||||
- Caution
====(1) Main modifications.
- a. Connecting rod.
- b. Crankshaft.
- c. Flywheel.
(2) Required parts.
- b. Crankshaft.
- c. Flywheel.
- Crankshaft x flywheel
- Caution
5. VALVE MECHANISM
- a. Camshaft.
mm |
Valve clearance
mm |
Cam top center | ||||
| A | B | C | D | E | F | |||
EX:0.38 |
106 | 109 |
EX:0.35 |
110 | 110 |
EX:0.4 |
106 | 114 |
EX:0.3 |
104 | 110 |
- b. Valves.
| IN | EX | IN | EX | |
- c. Valve springs.
| Item | Outer | Inner |
- d. Valve spring retainer.
- e. Valve stem pad.
- f. Rocker support.
- g. Rocker arm spacer
- h. Push-rod.
- i. Valve lifter.
- Reference
(2) Required parts.
| 10 | 90072-72661
90072-72681 |
Pad, retainer | 8 | "O" |
- Caution
- b. Valves
| Item | Sports parts | ||||
| Face contact width mm |
| (limit) mm | 0.08 | ||||
- Caution
- c. Rocker support.
- d. Valve lifter.
6. LUBRICATION SYSTEM
- a. Oil pump
- b. Oil pan.
- c. Oil strainer.
- d. Oil cooling system.
| 10 | Clamp | 6 | ||
| 14 | Hose, oil cooler | |||
