Tech:Engine/K-Series/TRD
Link by Taz_Rx
Transcription
Stage I
(1) Main modifications
- a. Cylinder head gasket.
- b. Piston
- c. Piston rings.
(2) Required parts.
| Description | Qty. |
| Gasket,cylinder head | 1 |
| Ring set, piston | 4 |
| Piston w/pin | 4 |
(3) Assembling standards.
Stage II
1. PISTON & PISTON RINGS
(1) Main modifications.
- a. Piston
- b. Piston rings
(2) Required parts.
| Piston w/pin | 4 |
2. VALVE MECHANISM
- a. Camshaft
- b. Valves
- c. Valve springs.
(2) Required parts.
Replace with the above parts.
3. INTAKE & EXHAUST SYSTEMS
- a. Intake manifold.
- b. Exhaust manifold.
(2) Required parts.
(3) Assembling procedures.
- a. Carburetor.
- b. Accelerator linkage.
(2) Required parts.
STAGE III
1. CYLINDER HEAD
- Caution
(2) Required Parts.
- Caution
- The intake valve seat ring must protrude into the combustion chamber 1 mm more than the exhaust. (Refer to Fig. 3-2 & 3-b.)
- Caution
