Tech:Engine/K Series/Electronic distributor
How to wire a 5k electronic distributor
The 5K distributor is a pulse generating type with inbuilt ignitor (ignition module). There is a two pin toyota connector with a black wire (negative) and a black with orange tracer (positive).
Remove your old points distributor, the 4mm black wire going to the distributor points is connected to the black wire on the two pin plug (this is negative switching for your coil). Connect the black with orange tracer to the positive side of your coil.
Note: if you have a ballast resistor on your coil you will need to change it to a 12v non resistor coil (I used a Gt40 coil), so disconnect the wire from the loom at the bottom of your ballast resistor and go straight to the + of your coil.
Write up - KE20rollabus Edited by - towe001
http://www.rollaclub.com/board/topic/42941-how-to-wire-a-5k-electronic-distributor/#entry450206
