Tech:Engine/K Series/Gearboxes
T40/T50 (Toyota Factory 4/5 Speed Manual)
The T50 gearbox is a lot stronger than the K50 gearbox and is a split casing design. You can still purchase close ratio gearsets for the T50 gearboxes through TRD and also Quaife. The T40 or T50 gearbox can be adapted to a K series motor with a K-T Bellhousing,
2. Hydraulic clutch K-T Bellhousing, Rare, Requires hydraulic clutch setup to be installed. (Off KT174 5K T40/Carina, KT14x series Corona)
CLUTCH FOR K-T50:
Although the K-T50 bellhousing in any form is very rare, nearly every clutch manifacturer make a kit for it. When looking for a ke20-70 clutch kit you may be asked "is it a 19 or 21 spline?"
You may also notice that between different clutch manifacturers the middle number in the dimentions (input shaft diametre) may be different. For example PBR list the K-T50 kit as 180x28.3x21T. This is because they measure the diametre of the shaft in the vallies, whereas say Exedy measure it on the peaks of the spline.
GEARBOX SELECTION - Which one to use?
There are a few different type of T50 gearboxes, and you need to be selective on which one you use for a K-T.
Shifter position:
TA22 & T18 T50's share a "ke30-55" shifter position. The AE86 and AE71 T50's have a "ke70" shifter position.
TA22 & T18 T50's both also have a 20 spline output shaft, just like a ke20-70 corolla. The gearbox is also the same length so there is no tailshft mods required to use one! The later (AE86/AE71)ones are 22 spline output and will require the tailshaft yoke to be swapped.
The WX0 (W40/W50) gearbox will fit if you use a K-W bellhousing from a KM20-36 Liteace.
This bell housing will bolt up to 4x of the 7x bolt holes on a W40 or W50 celica STEEL CASE gearbox, however you will need to grind a small amount out of the back of the bell housing to clear a "welse plug looking thing" on the gearbox - see the below link for pictures of this. I have mine bolted to (see below pic) an RA40 celica W50.
TAILSHAFT: The W50 GB is the same overall length as a K40/50, so no tailshaft shortening/lengthening is required. However the output spline is MUCH bigger and a corolla tail shaft needs to have the RA40 yoke transplanted onto it. This can be done with an old Holden (of all things) uni joint!! (Pictures courtesy of Taz_rx)
See also:
W5X (Toyota Factory 5 Speed manual)
This option is probably a bit of an overkill for a K series motor, but by using the bell housing from a KR42R (7kc/e powered) townace allows you to fit a W55, W56 etc celica/supra ALLOY CASE GB. To do so you will need to use the townace flywheel, clutch kit, fork and retainer, as well as the slave cylinder as this is a HYDRAULIC ONLY clutch. The townace 7k flywheel is still the same overall diametre as a corolla one, but has a bigger again 215mm clutch plate surface, so clutch dimentions are 215x29.8x21T, again here is the Exedy listing... http://www.exedy.com.au/SpecSheet.aspx?SpreadsheetRowId=14829 Suprisingly again there is a brass button option.
Below is a W56 from a KR42R, still attached to a 7KC.
Article by Medicine_Man / Taz_Rx / Xany / tojo2
Back to K Series
