Upgrades:KE70 Single to Twin Headlight Wiring
Jump to navigation
Jump to search
When converting from KE70 single to twin headlights, You need to power up the inner lights on high beam. This can be done by simply tapping a power feed into one side of the inner headlight filament and a high beam frame signal to the other.
Red/Black - Common 12v (Switched 12v feed via headlight relay when low beam activated).
Red/Green - Low Beam Frame (Switched to frame via headlight combo switch).
Red/Yellow - High Beam Frame (Switched to frame via headlight combo switch).
