Tech:Engine/K Series/Gearboxes
T40/T50 (Toyota Factory 4/5 Speed Manual)
The T50 gearbox is a lot stronger than the K50 gearbox and is a split casing design. You can still purchase close ratio gearsets for the T50 gearboxes through TRD. The T40 or T50 gearbox can be adapted to a K series motor with a K-T Bellhousing,
2. Hydraulic clutch K-T Bellhousing, Rare, Requires hydraulic clutch setup to be installed. (Off KT174 5K T40/Carina, KT14x series Corona)
The W5x (W50/W55) gearbox will fit if you use a K-W bellhousing from a KR42 Townace.
See also:
Article by Medicine_Man / Taz_Rx / Xany / tojo2
Back to K Series
