Upgrades:Corona Power Mirrors into late KE70/AE71
Swapping Corona Avante power mirrors into late KE70 / AE71 mirrors
Thanks to Teddy we have found out that the Corona Avante power mirrors are almost the same as a KE70. They share the same dimension mirror, Though the base is slightly different (Different body lines). In this guide I will explain how we converted the standard KE70 mirrors to house the Corona power mirrors. (Corona Avante mirror base on the left, Late KE70/AE71 mirror base on the right).
With the Corona mirror base, you can see it does not follow the door line at the bottom. I also noticed only one of the screws lines up with the holes on the back.
The AE71/KE70 base actually follows the line of the door, You have to modify it to fit the clip in that the spring connects to.
You will need,
Late KE70 / AE71 mirrors
Corona Avante Mirrors
Corona Avante Mirror switch with wiring plug
Corona Power Mirror Wiring Diagram
Dremel and a Cordless drill
Small pin punch and vice grips
This is the Corona Avante Power Mirror Switch.
This is the Wiring Diagram for the power mirrors.
Red/Green - 12V Fused Power (Off Ignition Switched Power) White/Black - Earth to Chassi of vehicle Light Green/Red - Mirror Common Power Brown/Yellow - Left Hand Mirror, Up and Down Brown/Black - Left Hand Mirror, Left and Right Light Green/Black - Right Hand Mirror - Up and Down Light Green - Right Hand Mirror, Left and Right
