Tech:Engine/A Series/Installing EFI Lifter Pump into AE86 Fuel Tank
cheap tramadol buy cyclobenzaprine cheap norco cheap celexa cyclobenzaprine online ultram online cheap propecia celexa online verizon ringtones xenical online cheap ambien cheap albuterol ultram online cheap ultram buy tramadol cheap ambien cheap carisoprodol mp3 ringtones online norco vicodin online sony ringtones hoodia online sildenafil online cheap vicodin motorola ringtones free jazz ringtones free qwest ringtones cialis online cheap ambien cheap lisinopril free verizon ringtones cheap valium cheap ultram buy meridia levitra online xenical online free cool ringtones ortho online cheap xanax fioricet fioricet nokia ringtones lipitor online mono ringtones buy diethylpropion free sharp ringtones jazz ringtones cheap diethylpropion cheap phentermine hydrocodone online sharp ringtones free sony ericsson ringtones cool ringtones order flexeril cheap didrex free nextel ringtones buy zyban free ericsson ringtones hoodia online tracfone ringtones cool ringtones music ringtones clonazepam didrex online online ultracet celexa online flexeril online free sagem ringtones free tracfone ringtones order zyban lortab online ultracet online lorazepam online online zoloft nexium online cheap xenical nokia ringtones mono ringtones free nextel ringtones free motorola ringtones lortab online cheap diazepam free qwest ringtones tramadol online levitra online clomid online buy levitra sprint ringtones punk ringtones prozac online order nexium lortab online flexeril ambien online funny ringtones hgh online polyphonic ringtones buy diethylpropion adipex online free sony ericsson ringtones ativan online free sagem ringtones meridia online flexeril cheap clonazepam buy flexeril cheap ultracet diethylpropion online free mtv ringtones real ringtones albuterol online xanax online lisinopril online cheap ultram alprazolam online jazz ringtones sprint ringtones cheap fioricet alltel ringtones nextel ringtones prozac online zyban online hydrocodone online xenical online vicodin soma online tenuate online free motorola ringtones free polyphonic ringtones ortho albuterol online cheap prozac but clonazepam free funny ringtones nextel ringtones samsung ringtones tracfone ringtones hgh online cheap xenical fioricet online wellbutrin online lipitor online order viagra valium online zanaflex online sprint ringtones free nokia ringtones polyphonic ringtones nokia ringtones free kyocera ringtones didrex cingular ringtones valium online free qwest ringtones cheap carisoprodol free sprint ringtones free sharp ringtones cyclobenzaprine online tenuate online diethylpropion online order rivotril free sagem ringtones buy ultram mono ringtones tenuate online samsung ringtones rivotril online nextel ringtones cheap clomid buy ativan buy tramadol cheap didrex sprint ringtones but ultracet cheap tramadol buy propecia free sharp ringtones tenuate tramadol online real ringtones free nokia ringtones cialis online ativan online cingular ringtones buy ultram viagra online cheap clonazepam viagra online sprint ringtones cheap zoloft zanaflex online buy carisoprodol nokia ringtones free sony ericsson ringtones cheap ultracet samsung ringtones zoloft cheap ativan levitra qwest ringtones During my 4A-C to 4AGE engine conversion in my Australian AE86 sprinter it came time to upgrade the fuel system to be able to meet the new demand for fuel. Being a naturally aspirated engine beforehand there is no in-tank fuel pump, only a mechanical fuel pump on the engine (driven by the camshaft). Japanese AE86 Sprinters on the other hand came from factory with a 4AGE engine and the EFI tank to suit. I had 2 options, find a tank from a Japanese AE86 (Can be expensive) or install my own generic lifter pump setup inside the tank. I opted to use a VK/VL Commodore lifter pump inside the tank. (This setup could also be adapted to other non efi tanks (KE70/AE71 etc).
(Lifter pumps are designed to suck the fuel, not pump it at a high pressure so you will also need to use a Hig pressure external pump with this setup).
To start with I removed the fuel line setup from the top of the fuel tank.
The Lifter Pump will be fitted where the old in-tank fuel filter is, it can be removed easily.
The Lifter Pump I'm using is from a VK/VL commodore
Here is what the Lifter Pump looks like with the fuel filter on.
I had to hacksaw a fair bit off the end of the fuel pickup line to get the lifter pump to sit where it needed to in the bottom of the tank. A few test fits and I clamped the lifter pump to the fuel pickup line.
Here is a shot of the Lifter pump mounted to the fuel pickup line.
This is the VL Commodore In-Tank Lifter Pump assembly I bought from the wreckers for $55.00, I bought this for the wiring connector and the wires. I Decided against running normal wire inside as I don't know how long it would last before the petrol chewed it away. An auto sparky I taked to said the same thing I was thinking, use the wiring out of another in-tank setup.
Here is a closeup of the wiring connector that I removed to install into my setup.
Another advantage of using the wires from the VL lifter pump setup is that the connectors for the lifter pump wiring are already crimped and properly insulated.
Here is a photo of where I drilled a hole in the AE86 fuel line setup for the VL wiring connector to go.
Underside shot of where I drilled the hole in the AE86 fuel line setup for the VL wiring connector to go.
The VL In-Tank wiring connector removed from previous setup.
The VL In-Tank wiring connector installed / wired into the AE86 fuel line setup. (bottom view).
The VL In-Tank wiring connector installed to the ae86 fuel line setup (Top view)
The complete converted setup ready to install into AE86 fuel tank.
Article by Medicine_Man
VN Commodore's use the same wiring and a very similar fuel pump as VL commodore's, The VN pump is longer so more of the ke70 in tank piping would need to be cut off. All the instructions above are the same for Ke70/Ae71.
It is best to to use wiring from another fuel tank as normal wire insulation might get eaten away from the petrol.
Make sure you get a VN in tank pump for a lift pump as the VP in tank pump is a pressure pump. You can use just one pressure pump in the tank but it WILL surge on hard cornering with 1/4 tank or so and that can lead to your pump seizing and failing.
The Ke70/Ae71 fuel tanks are not baffled nor have an internal swirl pot. - AE70
Back to A Series Engines
